ZoneAlarm 5.1.011 is out!
Jul 30, 2004 7 Replies
Jump to replies (7)
ZoneAlarm Pro
ZoneAlarm with Antivirus
ZoneAlarm Security Suite
-- TO REPLY REMOVE THE "X" FROM MY DOMAIN NAME. =____________________________- ////// (____) RKBA _____| (/////___________________(_____| Giovanni Lentini (/ /( )/o/)_/)_/)_/)_/) (/ 0 /_\\__)) snipped-for-privacy@rkba.net (/ /) (/ /) (/ 0 /) (/____ /) =======
It is still a very average firewall.
Don
"Giovanni Lentini" a écrit dans le message de news: snipped-for-privacy@4ax.com...
*Giovanni Lentini* wrote: [some Zonealarm 5.1.011.000 links]
FYI: Still seems broken with IIS5 Win2K SP4 (+all patches) The bug that randomly blocks access to files on localhost does not seem to be fixed. E.g. intermittent serving failures on non-ASP files. Failures cascade until a connection with localhost is lost completely. Adding localhost to trusted zone doesn't help. Makes it a bit difficult to build web apps when you can't talk to the server running on the same box :-(
Just uninstalled 5.1.011 and rolled back to 4.5.538.001 and those problems have gone.
Which one would you recommend?
Look'n Stop is a superior product IMHO!
Lots of users in the ZoneLabs forum are having significant trouble with the
5x beta (and final release) upgrades. You might want to stick with 4.5 until they sound happier over there.
4.5 is still working fine, and the upgrade is not urgent.
Ma No
After much trouble with 5.0 I've downloaded 5.1.011 and found it to be much improved, even over previous versions. I have a
128MB/PIII450/Win98SE system and even ZA4.5 seemed to use much resource and a high proportion of the processor time. This newest version seems to be much lighter in its use of machine resources. I'm happy with it (so far).
Sam squirted these wordjisms deep inside the bumtube of the newstwat in news: snipped-for-privacy@uni-berlin.de:
I agree. The previous version was f***ed, this one works and dosn't spazz off.
