VPN and routing between branches
Jul 21, 2005 4 Replies
Jump to replies (4)
Hi, I have established a VPN between two ZyWALL 5 routers in two different places. Both are connected to the DSL Internet connection with fixed IP address.
My configuration looks like this:
Branch A
- ZyWALL WAN IP- xxx.xxx.xxx.86
- Key Management - IKE
- Local IP Address - 192.168.0.1 - 192.168.0.253
- Remote IP Address - 192.168.10.1 - 192.168.10.253
- Encap. - Tunnel
- IPSec Algorithm - ESP DES SHA1
- Secure Gateway Address - xx.xx.xxx.146
- Authentication Method - Pre-Shared Key
- My IP Address - 0.0.0.0
Branch B
- Local IP Address - 192.168.10.1 - 192.168.10.253
- Remote IP Address - 192.168.0.1 - 192.168.0.253
- Encap. - Tunnel
- Secure Gateway Address - xx.xx.xxx.86
I can see that the tunnel between branches is established with success, but cannot reach (i.e. ping) hosts from A to B and oposite.
Why is that?
For any help thanks in advance With best regards Mike
Can any of the hosts use the internet?
All hosts in both branches can use Internet.
Hi, I manged this problem and succeed! It was the matter of upgrading firmwares.
Best regards Mike
Was that supposed to say you mangled this problem or you managed this problem. Either way, it sounds like the problem was a PEBCAK error. Word.
