Cisco ASA with strongswan
Jan 24, 2009 2 Replies
Hi
I try to connect strongSwan U4.2.11 with Cisco ASA 8.0.(3). I have problem with stability of that link. I sometimes lose connection after 10-20 min, sometimes more often. The link die and i must restart whole ipsec on both sides. I try various options but i cannot set proper configuration. When the link is dead on my SWAN ipsec status show me that ISAKMP and IPSEC are established but Cisco show me that only isakmp is established. I'm not sure that my cisco conf is correct to work with stongswan. Thx for help or some clue
regards Ted
It's my architecture:
LAN:10.10.10.0/24 +
30.30.30/24---SWAN=192.68.1.1/30===192.168.1.2/30=Cisco---50.50.50.0/24
My cisco conf:
access-list e01 extended permit ip 50.50.50.0 255.255.255.0 10.10.10.0
255.255.255.0
access-list e02 extended permit ip 50.50.50.0 255.255.255 30.30.30.0
255.255.255.0
crypto ipsec transform-set e01 esp-3des esp-sha-hmac crypto ipsec transform-set e02 esp-3des esp-sha-hmac
crypto map outside_map 40 match address e01 crypto map outside_map 40 set peer 192.168.1.1 crypto map outside_map 40 set transform-set erwin01_w_wawie crypto map outside_map 40 set security-association lifetime seconds 86400 crypto map outside_map 50 match address e02 crypto map outside_map 50 set peer 192.168.1.1 crypto map outside_map 50 set transform-set erwin01 crypto map outside_map 50 set security-association lifetime seconds 86400
crypto isakmp policy 10 authentication pre-share encryption 3des hash sha group 2 lifetime 28800
vpn-idle-timeout none vpn-session-timeout none
tunnel-group 192.168.1.1 type ipsec-l2l tunnel-group 192.168.1.1 general-attributes default-group-policy LAN2LAN tunnel-group 192.168.1.1 ipsec-attributes pre-shared-key * isakmp keepalive threshold 20 retry 2
logs from cisco:
a lot of:
Error: Unable to remove PeerTblEntry Error processing payload: Payload ID: 1 Removing peer from peer table failed, no match!
it's my Swan conf config setup interfaces=%defaultroute plutodebug=control crlcheckinterval=180 strictcrlpolicy=no nat_traversal=yes uniqueids=yes conn %default type=tunnel authby=secret ikelifetime=28800 keylife=86400 keyingtries=5 auto=start keyexchange=ike pfs=no auth=esp esp=3des-sha1 #dpdaction=hold #dpddelay=60 #dpdtimeout=500
conn e01-cisco_vpn_asa left=192.168.1.1 leftsubnet=10.10.10.0/24 leftnexthop=192.168.1.2 leftsourceip=10.10.10.1 right=192.168.1.2 rightsubnet=50.50.50.0/24 rightnexthop=192.168.1.1
conn e02-cisco_vpn_asa left=192.168.1.1 leftsubnet=30.30.30.0/24 leftnexthop=192.168.1.2 right=192.168.1.2 rightsubnet=50.50.50.0/24 rightnexthop=192.168.1.1
ipsec statusall
000 %myid = (none)
000 debug control
000
000 "e01-cisco_vpn_asa": erouted; eroute owner: #3
000 "e01-cisco_vpn_asa": ike_life: 28800s; ipsec_life: 86400s; rekey_margin: 540s; rekey_fuzz: 100%; keyingtries: 5
000 "e01-cisco_vpn_asa": policy: PSK+ENCRYPT+TUNNEL+UP; prio: 24,26; interface: eth1;
000 "e01-cisco_vpn_asa": newest ISAKMP SA: #0; newest IPsec SA: #3;
000 "e01-cisco_vpn_asa": IKE algorithms wanted: 7_128-2-14,
000 "e01-cisco_vpn_asa": IKE algorithms found: 7_128-2_160-14,
000 "e01-cisco_vpn_asa": ESP algorithms wanted: 3_000-2,
000 "e01-cisco_vpn_asa": ESP algorithms loaded: 3_192-2_160,
000 "e01-cisco_vpn_asa": ESP algorithm newest: 3DES_0-HMAC_SHA1; pfsgroup=
000 "e02-cisco_vpn_asa": erouted; eroute owner: #4
000 "e02-cisco_vpn_asa": ike_life: 28800s; ipsec_life: 86400s; rekey_margin: 540s; rekey_fuzz: 100%; keyingtries: 5
000 "e02-cisco_vpn_asa": policy: PSK+ENCRYPT+TUNNEL+UP; prio: 26,26; interface: eth1;
000 "e02-cisco_vpn_asa": newest ISAKMP SA: #2; newest IPsec SA: #4;
000 "e02-cisco_vpn_asa": IKE algorithms wanted: 7_128-2-14,
000 "e02-cisco_vpn_asa": IKE algorithms found: 7_128-2_160-14,
000 "e02-cisco_vpn_asa": IKE algorithm newest: 3DES_CBC_192-SHA-MODP1024
000 "e02-cisco_vpn_asa": ESP algorithms wanted: 3_000-2,
000 "e02-cisco_vpn_asa": ESP algorithms loaded: 3_192-2_160,
000 "e02-cisco_vpn_asa": ESP algorithm newest: 3DES_0-HMAC_SHA1; pfsgroup=
000
000 #3: "e01-cisco_vpn_asa" STATE_QUICK_R2 (IPsec SA established); EVENT_SA_REPLACE in 84315s; newest IPSEC; eroute owner
000 #3: "e01-cisco_vpn_asa" esp.a96f310f@192.168.1.2 esp.2b6f7bc5@192.168.1.1; tunnel
000 #4: "e02-cisco_vpn_asa" STATE_QUICK_R2 (IPsec SA established); EVENT_SA_REPLACE in 84315s; newest IPSEC; eroute owner
000 #4: "e02-cisco_vpn_asa" esp.d0c44a83@217.74.64.182 esp.dc38acab@192.168.1.1; tunnel
000 #2: "e02-cisco_vpn_asa" STATE_MAIN_R3 (sent MR3, ISAKMP SA established); EVENT_SA_REPLACE in 26714s; newest ISAKMP
000 Performance: uptime: 30 minutes, since Jan 24 22:07:07 2009 worker threads: 10 idle of 16, job queue load: 1, scheduled events: 0 loaded plugins: aes des sha1 sha2 md5 fips-prf random x509 pubkey xcbc hmac gmp kernel-netlink stroke updown Listening IP addresses: 192.168.1.1 Connections: Security Associations: none
Hmmm - working a bit.
Not sure but have a look at the following.
Well you are not referencing the defined transform sets from the crypto map?
As far as I know it is not necesary to defing multiple transform sets, so -
crypto ipsec transform-set my-ts esp-3des esp-sha-hmac
crypto map outside_map 40 match address e01 crypto map outside_map 40 set peer 192.168.1.1 crypto map outside_map 40 set transform-set my-ts crypto map outside_map 40 set security-association lifetime seconds
86400 crypto map outside_map 50 match address e02 crypto map outside_map 50 set peer 192.168.1.1 crypto map outside_map 50 set transform-set my-ts crypto map outside_map 50 set security-association lifetime seconds 86400
For further simplification you mmight consider:-
10.10.10.0 255.255.255.0 access-list e01 extended permit ip 50.50.50.0 255.255.255.0 30.30.30.0 255.255.255.0
86400
This may be telling you what is wrong.
Wanted and Found should probably be the same.
000 "e01-cisco_vpn_asa": IKE algorithms wanted: 7_128-2-14, 000 "e01-cisco_vpn_asa": IKE algorithms found: 7_128-2_160-14,
bod43 pisze:
thx for help, i made as You suggest, but i have still problem. My links aren't stable, They works about 1-3 minutes and go down. Sometimes they work together, sometimes only one of them. After restart both links works for a 2-3 minutes
I try to test varius config, eg aes-256, change crypto etc:
crypto map outside_map 40 match address erwin01_w_wawie crypto map outside_map 40 set peer 192.168.1.1 crypto map outside_map 40 set transform-set my_ts crypto map outside_map 40 set security-association lifetime seconds 86400
crypto ipsec transform-set my_ts esp-aes esp-sha-hmac
crypto isakmp policy 10 authentication pre-share encryption 3des hash sha group 2 lifetime 28800 crypto isakmp policy 20 authentication pre-share encryption aes-256 hash sha group 2 lifetime 86400
clear crypto ipsec peer 192.168.1.1 clear crypto isakmp sa 192.168.1.1
but i still have:
IKE Peer: 192.168.1.1 Type : L2L Role : initiator Rekey : no State : MM_ACTIVE Encrypt : 3des Hash : SHA Auth : preshared Lifetime: 28800 Lifetime Remaining: 28678
In my logs i still have:
Error processing payload: Payload ID: 1 Removing peer from peer table failed, no match! Error: Unable to remove PeerTblEntry
and debug show:
,processing SA payload ,IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + NOTIFY (11)
  • NONE (0) total length : 96
, All SA proposals found unacceptable , Error processing payload: Payload ID: 1 , IKE MM Responder FSM error history (struct &0xd8b7ac38) , : MM_DONE, EV_ERROR-->MM_START, EV_RCV_MSG-->MM_START, EV_START_MM-->MM_START, EV_START_MM-->MM_START, EV_START_MM-->MM_START, EV_START_MM-->MM_START, EV_START_MM-->MM_START, EV_START_MM
, IKE SA MM:94edd0b6 terminating: flags 0x01000002, refcnt 0, tuncnt 0 , sending delete/delete with reason message
On my other site, strognswan:
ipsec.conf:
conn %default type=tunnel authby=secret ikelifetime=28800 keylife=86400 keyingtries=5 auto=start keyexchange=ike pfs=no auth=esp esp=aes128-sha1 #esp=3des-sha1 ike=aes256-sha-modp1536 #dpdaction=hold #dpddelay=60 #dpdtimeout=500
ipsec statusall
100%; keyingtries: 5 policy: PSK+ENCRYPT+TUNNEL+UP; prio: 24,26; interface: eth1; newest ISAKMP SA: #0; newest IPsec SA: #3; IKE algorithms wanted: 7_256-2-5, IKE algorithms found: 7_256-2_160-5, ESP algorithms wanted: 12_128-2, ESP algorithms loaded: 12_128-2_160, ESP algorithm newest: AES_128-HMAC_SHA1; pfsgroup=
