Can anybody help me with a problem regarding vpn on a asa5505. When the client tries to connect there is no answer.
Erik my config :
ASA Version 8.0(3) ! hostname ciscoasa enable password jQUCdrURwbTfANCO encrypted names ! interface Vlan1 nameif inside security-level 100 ip address 192.168.10.100 255.255.255.0 ! interface Vlan2 nameif outside security-level 0 ip address 111.111.111.130 255.255.255.252 ! interface Vlan5 no forward interface Vlan1 nameif dmz security-level 50 ip address 192.168.11.100 255.255.255.0 ! interface Ethernet0/0 switchport access vlan 2 ! interface Ethernet0/1 ! interface Ethernet0/2 ! interface Ethernet0/3 ! interface Ethernet0/4 ! interface Ethernet0/5 ! interface Ethernet0/6 ! interface Ethernet0/7 ! passwd 2KFQnbNIdI.2KYOU encrypted ftp mode passive access-list asm_splitTunnelAcl standard permit 192.168.10.0
255.255.255.0 access-list inside_nat0_outbound extended permit ip 192.168.10.0
255.255.255.0 192.168.9.0 255.255.255.192 pager lines 24 logging asdm informational mtu inside 1500 mtu outside 1500 mtu dmz 1500 ip local pool dhcp-pool 192.168.9.1-192.168.9.50 mask 255.255.255.0 icmp unreachable rate-limit 1 burst-size 1 asdm image disk0:/asdm-611.bin no asdm history enable arp timeout 14400 global (outside) 1 interface nat (inside) 0 access-list inside_nat0_outbound nat (inside) 1 0.0.0.0 0.0.0.0 route outside 0.0.0.0 0.0.0.0 111.111.111.129 1 timeout xlate 3:00:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02 timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat
0:05:00 timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip- disconnect 0:02:00 timeout uauth 0:05:00 absolute dynamic-access-policy-record DfltAccessPolicy http server enable http 192.168.10.0 255.255.255.0 inside no snmp-server location no snmp-server contact snmp-server enable traps snmp authentication linkup linkdown coldstart crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP- AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP- DES-MD5 crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP crypto map outside_map interface outside crypto isakmp enable outside crypto isakmp policy 10 authentication pre-share encryption des hash sha group 2 lifetime 86400 no crypto isakmp nat-traversal telnet timeout 5 ssh timeout 5 console timeout 0 dhcpd auto_config outside !
threat-detection basic-threat threat-detection statistics access-list group-policy asm internal group-policy asm attributes dns-server value 192.168.10.10 vpn-tunnel-protocol IPSec split-tunnel-policy tunnelspecified split-tunnel-network-list value asm_splitTunnelAcl username username password uHOFjjaVl6M5D20f encrypted privilege 0 username username attributes vpn-group-policy asm tunnel-group asm type remote-access tunnel-group asm general-attributes address-pool dhcp-pool default-group-policy asm tunnel-group asm ipsec-attributes pre-shared-key * ! class-map inspection_default match default-inspection-traffic ! ! policy-map type inspect dns preset_dns_map parameters message-length maximum 512 policy-map global_policy class inspection_default inspect dns preset_dns_map inspect ftp inspect h323 h225 inspect h323 ras inspect rsh inspect rtsp inspect esmtp inspect sqlnet inspect skinny inspect sunrpc inspect xdmcp inspect sip inspect netbios inspect tftp ! service-policy global_policy global prompt hostname context Cryptochecksum:d4ff87b561b51134b8f2e702551d9ebd : end [OK]
