SpywareBlaster query...........
Aug 27, 2005 2 Replies
SpywareBlaster doesn't need to be running to provide its protection, so don't worry about forgetting to load or run it. SpywareBlaster's blocking is done by registry entries (setting "kill-bits"). Download it, install it, run it, update it, enable the protection(s), and close/exit it. That's it! After that you'll only need to run it when updating or making changes, other than that you can leave it closed.
How do you set it up to run automatically upon start up ?
With such a useful programme - Is there is risk getting spyware on your system if you forget to load it up manually ?
Regards,
Jim
"jimbo" wrote in news:HQ2Qe.810$h4.251@newsfe4- win.ntli.net:
It is snake oil.
Duane :)
