Sality is a malicious file infecter virus that will inject its malicious code into many executable files on an infected computer. This virus also comes with a malware that infects and overwrites the autorun.inf file for auto-play. Once your computer is infected with Sality, it will be able to connect to remote server and download more components of it or other malwares, it can also run executable files in hidden mode. Sality virus will use a file with the name %variable% to copy itself to removable media like USB / Pen drives. this file may have extension of .exe , .pif or .cmd. Sality malware will remove registry entries from infected computer to disable safe mood boot. it will also add registry entries to disable your task manager and disable registry editing tools, it will also block security center options....
