REQ: How to Zero Out Reset Palm 700p?
Dec 24, 2006 2 Replies
Bill Marcum
[OP set followup to - why, I have no idea.] Have you tried Palm tech support or your cell provider? Sounds like you may need to return the Treo.
My phone's dead for the holidays. I've tried zero-out reset about 30 times and no matter how carefully we do it, always get the rainbow screen, so I'm tempted to think it doesn't work on the 700 - anybody know otherwise?
My palm's stuck in a continuous reset loop with its battery in, and hard resets, soft resets, etc, do absolutely nothing, I get to the point where pressing "Up" will delete all my data, then the machine simply resets itself again!!
Try resetting with the "up" key pressed. Do not let it go until you see the palm launcher.
