port forwarding with 2 routers in a row
Mar 19, 2005 0 Replies
Need help from out there!
Following setup:
I use my Grandstream ATA 486 behind the DSL and connect my netgear FR114P to the ATA - This Setup was recommended by grandstream to use my IP-Phone (connected to the ATA) with the best connection. Guess the setup is OK.
The only problem i have: how do I setup port forwarding through this 2 routers? I setup the port forwarding on the FR114P and the ATA486 as described under
but it doesn´t work (as i still have a low ID on emule). I guess the problem is the ATA 486. The setup there is as follows:
WAN-Port .... LAN-IP ..... LAN-Port ...... TCP/UDP
I´m not sure if WAN and LAN port are the same and if the LAN-IP should be the one from the FR114P (192.168.0.1) or the Static Ip from my computer (192.168.0.11) which i setup for the FR114P.
Hope there are some good hints out there. THANX in advance
roland
