PIX and VLANs
Mar 05, 2007 5 Replies
Jump to replies (5)
PIX and VLANs open original image
I am researching the requirements to configure a pix 515E connected to a Cisco 2950 switch. I am researching the requirements to enable VLANS between these two devices. What do I need to look for a and what kind of problems could be encountered?
Thanks ICEMAN
You may wish to investigate Cisco 2950 Technical Docs:
as well as PIX
and PIX Software
Sincerely,
Brad Reese on Cisco Network World Magazine Cisco Subnet
Could you possibly give some more details? It should not be a problem configuring these 2 devices to work together.
The PIX 515E will require PIX 6.3(1) or later software release. The 2950 should be usable with any IOS that has been supported for it.
Was there something more specific you were looking for? e.g., do you need to know things such as that you won't be able to terminate a VPN connection on the VLAN interface on the PIX?
When VLANs are used on a switch you have to setup a router. VLANs will create two different networks that can't talk to each other with out a router. You will get "Network destination unreachable" error with ping, if you don't setup a router.
The PIX 515E running PIX 6.3(1) or later software is able to route packets between 802.1Q VLANs. You do not need to add a seperate "router".
