How to configure two routers with two ISPs and PIX 515 with failover with BGP?
Sep 28, 2005 4 Replies
ashaffer
Hope this helps Qwest ---------- Router 2 ------- PIX FO ------- | | failover | Megapath----- Router 1 -------- PIX ----------
This is what we have
2 Cisco 2801
1 PIX 515e
1 PIX 515e FO
ISPs Megapath Qwest
There is public addresses between the 2801s and pixes.
Any help on this would greatly be appreciated.
Andrew
Hope this helps
snipped-for-privacy@tranztec.com schrieb:
No, it does not. What kind is your IP space. PI or PA?
Christian
this really doesnt do you any good. If Megapath breaks on the WAN side of the router, your PIX will not failover.
you need a segment inbetween, a switch, that holds both routers and both PIX's and then OSPF and HSRP between the two routers.
then you need to address the public IP range side of this. you need a Provider Indepeendant Range - a PI range aasigned to you. next you need to arrange the BGP with the two providers. and keep in mind the slow convergence times of BGP.
HTH Martin Bilgrav
IP space is almost immaterial, as long as both ISPs agree to advertise it and you have an ASN. Basic design is to have one router peer (EBGP) with Qwest, the other peer (EBGP) with Megapath, run IBGP between them, run HSRP between them for the PIX to use for default GW, configure PIX to be default GW for interior users. That eliminates PIX, routers, lines, and ISPs as single points of failures. Does not eliminate switches or configuration errors as a single point of failure. From the viewpoint of the design, the PIX and the failover PIX are a single box with a higher availability (and some weird failure modes, but that is a different can of worms).
Set up details for BGP will depend upon relative importance of fail over versus load balancing versus budget. Other approaches are possible, depending upon your specific requirements.
Good luck and have fun!
