how to set up switch, PIX and router using VLANs
Oct 24, 2006 1 Replies
Walter Roberson
You cannot route VLANs individually on a PIX, unless you are using 7.x software and VRF (Virtual Router Facility) so that each VLAN sees a different router table. (Though there might be other selective routing mechanisms in 7.x that I haven't happened to encounter yet.)
i've got a 2950 switch, 2611 router and 515 pix i want to set them up so that i route different VLANs through the firewall i plan to set the equipment up in this order
----------------------- | | | router | | |
----------------------- | | | pix | | |
----------------------- | | | switch | | |
is this correct?
