Most users on this NG are looking for help because they "don't know what they are doing". The "Experts" typically are happy to help those of us who are not experts. Your responses to any questions are typically cynical and ambiguous. Your above response 'Non RFC-conformant behavior (What's that?), 'Broken PMTUD' (What's that?), 'broken Load Balancing' (What's that?) do nothing to help the OP. Throwing out industry 'Buzz Words' to a layman is not productive.
I suspect that you probably do have something to contribute. However, over the time that I have been lurking on this NG, I have only seen 'one liners' and sarcasms.
Help. My Router keeps dropping packets and i dont know if this is normal orif...
M
Mr. Arnold
What network are you referring to? Are you referring to the network connectivity that the machine can access the Internet, which the Internet is a giant network. Blocking those ports meant nothing, because once again, the router is setting there blocking those ports? Your machines are NOT in a networking situation on ports 137-139 UDP and 445 TCP from another machine over the Internet. That should never happen.
Yes, your machine is connected to the router and therefore it's connected to the Internet networking. Machines don't need to use 137-139 UDP or 445 TCP to network and communicate with each other there are
65,000 some other ports that machines can use to network on.
However, for the MS O/S in order for the machines to network with each other to share files and the printer, the printer being on a host machine, then 137-139 UDP and 445 TCP are the *standard* ports that have been assigned to do that.
The fact is that you're not networking the machines in the first place on the LAN, even with the services for networking on the NIC(s).
If you actually were to try to access one machine from the other on your LAN, like logon to the remote machine and access its directories, etc, then you're going to have problems, because you have blocked the ports with the PFW.
The machines on the LAN are not networking, so it's a moot point that you have blocked those ports. And you're not going to see any problems with any networking because you blocked them, until you start trying to network the machines on your LAN.
It would be one thing if you passed that test with a computer that had a direct connection to the modem, which is a direct connection to the Internet, using a PFW.
That test really means nothing, because once again, the machine is setting behind a router. The router has all ports closed by default. It's a bogus test that you're doing.
S
Sebastian Gottschalk
Fine. If you don't have any clue about TCP/IP networking, you shouldn't try to run a host-based packet filter. Anything else is unreasonable.
What's Google? Hey, after all, why didn't the OP find out about these things *before* he implemented his host-based packet filter?
These are no buzzwords.
L
louise
Thanks for explaining. I will know that I blocked networking, if I ever do want to network the two machines and I will remove the firewall rule I created.
As soon as I get a chance, I will connect each machine separately to the modem, thereby removing the router, and use Shields Up again. I may be back with more questions when I do, but at least I'll know why I'm asking them :-)
Louise
Report Content
ASAP.
