Norton Interet Security Issue
Dec 19, 2004 1 Replies
When browsing more and more sites the banners don't come up - I looked at
and the screen is mostly blank - if I turn off Norton then the site loads as it should - problem also with Yahoo Jobs
- I can see the jobs but the link to further information does not appear unless I turn Norton off.
Any idea's ? Thanks
Well, if you don't want to use their ad blocking feature then disable it. Or add a web content filter that doesn't block whatever the default web content filter blocks.
