LAN problem with TPF
Feb 21, 2005 1 Replies
Make sure that TPF is turned on and enabled, then begin to talk dirty to it.
I'm having a XP Home LAN problem. In Network Places I can see other machines' drive icons but can't open them to see the folders and files unless I turn off the firewall on the machine being viewed. This LAN previously worked until I replaced one of the two machines (98SE) with another (XP Home). Now both are XP Home. AFAIK I didn't change anything in the firewall or LAN on the original XP machine.
How can I tell Tiny Personal Firewall 2.0.15A not to block LAN connections/ports?
TIA
