Has anybody experienced the Kerio 2.1.5 filter rule set being reset to the default set for no apparent reason? This was happening on my computer for a while, now it seems to have stopped happening. Then, I installed the firewall on a friend's computer and it just happened to THAT computer.
Does anybody know why this is happening?
TIA
Error msg. say's: unable to init FwDrv driver:2. Can anyone tell me...
D
deadguy3
try password protection in options. export rules so its easy to recover. set perf conf as read only file.
J
John Corliss
Thanks very much for replying.
Yes, I backed up the ruleset file yesterday. Was just hoping to find out if anybody knew what was causing the file to get reset in the first place.
I
Ian Cowan
Hi John,
Short answer no.
I also use same version of kerio. When i installed it i followed suggestions as per pacman's portal & answers that work sites which pointed me to "personal firewall" kerio & tiny personal firewall
- i forget the exact url but i have it somewhere. - sorry not much help so far.
i made up rules as suggested. then [as suggested] ran kerio in 'learn ' mode.
I finished up with 8 different rule sets - you can load / or save different sets as desired.
I'd be quite willing to swap conf sets. yours might be better than mine.
Back to your original question.
what else is running Anti-virus ? anti spyware ?
maybe check with Hijack this & post the contents of the log here and maybe to a free tech-tips site.
some progs in (1) might cause "it" to happen
3, (paranoia) malaware etc
HTH
Ian C
Report Content
ASAP.
