IPCOP USB Support... USB not enabled?
May 30, 2006 1 Replies
Simon Pickard
I would suggest a good forum to post this in would be the IPCop forum at - just might be someone there that can help Simon
I added apcupsd to my IPCop box, and its not seeing the UPS. Until I connected it, I had disabled the USB controller in the BIOS because it wasn't needed, but now I'm noticing that there's no usb listed in lsmod
(shown below) and no /proc/bus/usb.
I've looked around online, and found that many people have USB enabled on their IPCop machines, in fact for some it's required to operate, but
I'm at a loss as to how to enable it. Anyone have any ideas on what could be causing this?
Thanks all,
Richard
lsmod info Module Size Used by Not tainted ipsec_twofish 35332 0 (unused) ipsec_sha2 7800 0 (unused) ipsec_sha1 18488 0 (unused) ipsec_serpent 11076 0 (unused) ipsec_md5 4440 0 (unused) ipsec_blowfish 8420 0 (unused) ipsec_aes 31624 0 (unused) ipsec_3des 17052 0 (unused) ipsec 255268 2 [ipsec_twofish ipsec_sha2 ipsec_sha1 ipsec_serpent ipsec_md5 ipsec_blowfish ipsec_aes ipsec_3des] ipt_MARK 696 28 (autoclean) sch_ingress 1380 1 (autoclean) cls_u32 4380 5 (autoclean) sch_sfq 3008 3 (autoclean) sch_htb 18688 1 (autoclean) ipt_MASQUERADE 1272 1 (autoclean) ipt_mark 440 2 (autoclean) ipt_TCPMSS 2168 1 (autoclean) ipt_state 504 17 (autoclean) ipt_REJECT 2968 1 (autoclean) ipt_LOG 3616 9 (autoclean) ipt_limit 792 10 (autoclean) iptable_mangle 2008 1 (autoclean) iptable_filter 1612 1 (autoclean)
8139too 13128 1 mii 2112 0 [8139too] crc32 2880 0 [8139too]
3c509 10164 2 isa-pnp 27088 0 [3c509] ip_nat_quake3 1864 0 (unused) ip_conntrack_quake3 1992 1 ip_nat_proto_gre 1316 0 (unused) ip_nat_pptp 2156 0 (unused) ip_conntrack_pptp 2641 1 ip_conntrack_proto_gre 2069 0 [ip_nat_pptp ip_conntrack_pptp] ip_nat_mms 2736 0 (unused) ip_conntrack_mms 2928 1 ip_nat_irc 2032 0 (unused) ip_conntrack_irc 2864 1 ip_nat_h323 2380 0 (unused) ip_conntrack_h323 2161 1 ip_nat_ftp 2512 0 (unused) ip_conntrack_ftp 3664 1 iptable_nat 16142 8 [ipt_MASQUERADE ip_nat_quake3 ip_nat_proto_gre ip_nat_pptp ip_nat_mms ip_nat_irc ip_na t_h323 ip_nat_ftp] ip_conntrack 19480 7 [ipt_MASQUERADE ipt_state ip_nat_quake3 ip_conntrack_quake3 ip_nat_pptp ip_conntrack_p ptp ip_conntrack_proto_gre ip_nat_mms ip_conntrack_mms ip_nat_irc ip_conntrack_irc ip_nat_h323 ip_conntrack_h323 ip_nat_ ftp ip_conntrack_ftp iptable_nat] ip_tables 10944 13 [ipt_MARK ipt_MASQUERADE ipt_mark ipt_TCPMSS ipt_state ipt_REJECT ipt_LOG ipt_limit ip table_mangle iptable_filter iptable_nat] apm 8644 0
There just might be someone there that can help
Simon
