HPING3
Mar 30, 2007 2 Replies
I wonder why HPING3 has two different flags for setting TCP ACK...
-A --ack: Set ACK tcp flag.
-L --tcpack: Set the TCP ack.
There has to be a difference, but I don't know.....
Can someone through some light on that ?
thanks
Soapp
[compton ~]$ whatis hping3 hping3 (8) - send (almost) arbitrary TCP/IP packets to network hosts [compton ~]$
Versatility.
0793 Transmission Control Protocol. J. Postel. September 1981. (Format: TXT=172710 bytes) (Updated by RFC3168) (Also STD0007) (Status: STANDARD)
Section 3.1 - you can find the RFC using the same search engine you are posting from.
What is the difference between 12th bit in the fourth 32 bit word (ACK) of a TCP header and the entire third 32 bit word of the header?
Old guy
Oh, I see,
-L --tcpack, sets the 32 Bit TCP ackknowledge Number :)
Thank you
