Ok. I am having the weirdest problem and I can't tell where the fault lays. So here is the situation
The other day we started experiencing a random internet outage. Well after some testing what I found out was that the firewall wasn't allowing any traffic past it for some odd reason. So after some more testing I found out that if I removed all the global addresses and made the company just use one PAT address then everyone could access the internet and get past the PIX. At first thought that maybe we had exhausted all of our IPs and the system was having a hard time building the translations. But me being a newbie at this means that I'm probably wrong. I went through every config line by hand and can't see where we would be block a whole range of IPs but then allowing one single ip to leave. I even checked our external router and I didn't see anything that would have caused such a problem. I mean my thinking is that if a whole range of IPs is blocked or not working, that would mean that even the PAT address I'm using would be blocked also. So after some more testing and increasing the logging, I came across this:
c 6 17:28:45 192.168.4.1 %PIX-6-609001: Built local-host inside:
192.168.4.81 Dec 6 17:28:45 192.168.4.1 %PIX-6-305009: Built dynamic translation from inside:192.168.4.81 to outside:##.##.##.## Dec 6 17:28:45 192.168.4.1 %PIX-6-302013: Built outbound TCP connection 4243573 for outside:64.246.26.120/80 (64.246.26.120/80) to inside:192.168.4.81/2032 (##.##.##.##/2032) Dec 6 17:28:51 192.168.4.1 %PIX-6-106015: Deny TCP (no connection) from 192.168.4.81/1872 to 72.14.253.125/443 flags PSH ACK on interface inside Dec 6 17:28:51 192.168.4.1 %PIX-6-302013: Built outbound TCP connection 4243646 for outside:72.14.253.125/5222 (72.14.253.125/5222) to inside:192.168.4.81/2033 (12.179.97.46/2033) Dec 6 17:28:53 192.168.4.1 %PIX-6-106015: Deny TCP (no connection) from 192.168.4.81/1875 to 216.155.193.168/5050 flags PSH ACK on interface inside Dec 6 17:28:59 192.168.4.1 %PIX-6-106015: Deny TCP (no connection) from 192.168.4.81/1896 to 64.12.26.90/5190 flags PSH ACK on interface inside Dec 6 17:28:59 192.168.4.1 %PIX-6-106015: Deny TCP (no connection) from 192.168.4.81/1927 to 205.188.13.36/5190 flags FIN ACK on interface inside Dec 6 17:28:59 192.168.4.1 %PIX-6-106015: Deny TCP (no connection) from 192.168.4.81/1920 to 205.188.176.105/5190 flags FIN ACK on interface inside Dec 6 17:28:59 192.168.4.1 %PIX-6-106015: Deny TCP (no connection) from 192.168.4.81/1917 to 205.188.248.146/5190 flags FIN ACK on interface inside Dec 6 17:28:59 192.168.4.1 %PIX-6-106015: Deny TCP (no connection) from 192.168.4.81/1914 to 205.188.153.2/5190 flags FIN ACK on interface inside Dec 6 17:29:07 192.168.4.1 %PIX-6-106015: Deny TCP (no connection) from 192.168.4.81/1977 to 207.46.111.19/1863 flags PSH ACK on interface inside
Does this even matter at all? Any help would be much appreciated, especially since I'm very new to the networking world. Thank you.
