Factory default Nokia IP650
Mar 13, 2006 9 Replies
Jump to replies (9)
Hi Everyone,
Does anyone know how to factory default a Nokia IP650 running V3.2.1?
Thanks,
Sam
Hm...
gives me for example:
Yours, VB.
VB, thanks, but I have the password. I was looking to completely wipe the box of all configuration.
Sam
Ah, sorry. AFAIK a Nokia IP650 is a BSD box with a hard disk. So for resetting this thing, just restore your backup.
Yours, VB.
rm /config/active
& reboot the system.
greg
Not really. It is based on BSD but is specific to Nokia. I have not done this in a few years but as I recall all you need to is delete a configuration file. I believe it is documented in the material shipped with the Nokia. If not, I believe it is outlined in a knowledge based article through nokia support.
Nokia itself documents IPSO as a BSD UNIX. Of course, this special distri- bution is by Nokia.
Yours, VB.
Ok I got it. Go to boot manager and type "INSTALL"
Thanks,
Sam
