Cisco Pix 501 VS SonicWall TZ 150
Sep 20, 2006 0 Replies
I was thinking about getting a firewall for my network. It seems the SonicWall is a little bit cheaper. Which one do you guys recommend over the other and why?
Two more questions:
I can operate either of these without buying any kind of yearly service contract right? Those are just extra filtering options and such?
Also, once I purchase a hardware firewall for the network, do you still recommend a software firewall to be turned on, or is it then safe to disable the software firewall?
Thanks for your expertise.
