Checkpoint routing
May 17, 2006 3 Replies
Jump to replies (3)
A question to all guru's
we have the following setup
----Internet-------Firewall/Gateway-----192.168.125.0/24---------router--------192.168.126.0/24----- | LAN1 LAN2
| DMZ
The current setup works ok but a "route add 192.168.126.0 mask
255.255.255.0 192.168.125.41" command (interface on router) needs to be added to workstations in the 192.168.125.0 network to access the
192.168.126.0 network. What my question is, are we able to set our checkpoint firewall/gateway (default gateway for all workstations on
125.0 network) to route to the 126.0 network doing away with having to add a persistent route on 'all' workstations?
Any help on the matter would be greatly appreciated
You could use another topology. With this topology you have, it's required to have the route in every routing table, if this should be sensible. You could send every packet to the default gateway, though, then sending it to router 2 afterwards.
You could use routing protocols, too, which configure your boxes more automatically.
Yours, VB.
Thanks VB,
Yep I know it's a poor topolopy. We only have about 80 PC's in LAN1, so I might push out the route with sysinternals psexec. We are migrating over to the new LAN2 so LAN1 should only be in existence for a few more weeks.
You can add a route to your firewall for 192.168.126.0/24 or just add one more interface with an IP address belonging to 192.168.126.0/24 on firewall.
The topology looks like ---------- 192.168.126.0/24 | Internet---firewall ---- 192.168.125.0/24 | DMZ
