rules for Cisco PIX 525 firewall rules
Oct 02, 2005 2 Replies
We have purchased a Cisco PIX 525 firewall. I have worked with Checkpoint in the past (1997-8) but never with Cisco firewall.
I would appreciate it if someone provide me with the basic rules i should have a on the PIX 525
In article , KAS wrote: :I would appreciate it if someone provide me with the basic rules i :should have a on the PIX 525
There are a lot of examples on cisco.com .
The PIX is fairly flexible, so it would not be productive for us to outline all the possible rules you -might- need.
The rule type you will need over and over again is the access-list . If you plan to configure your 525 though the CLI, you should become quite familiar with access-lists:
If your access-controls are going to be non-trivial, then I also recommend that you use object groups and the 'name' command in order to organize the access elements and make them more legible:
Thank you so much Christopher. Your links are very helpful. Take care
