ARES/keylogger?
Apr 19, 2005 2 Replies
Hi there, Thanks for your assistance. As you probably have already surmissed, I'm not exactly knowledgeable with things cybernetic. I did download the application you suggested, and several entries did appear after the scan. (BTW, I found another rootkit detector at Neither of…
ARES/keylogger? open original image
I downloaded a program (.exe) from Ares P2P.
When I tried to install it, a black screen appeared, disappeared, then nothing else happened. No program appears to have been installed.
I'm using MSXPHome, and have DSL. Nothing appears on a Norton's virus scan, nor as spyware. Could they detect a keylogger that I installed myself? Could it have been another spy program? Do autodialers work through DSL connections?
How do I know what type of program was installed?
Please answer locally on this NG. My email is obviously fake.
Thanks for any assistance.
": )" wrote
You could try the lastest toy - a rootkit revealer from here
Hi there,
). Neither of the two gives clear directions as how to interpret the data, nor what to do after you do ID a threat. They actually state that legit antivirus scans may produce a positive.
Any pointers?
Best Regards
M
Todger wrote:
