2 networks must be made one - question
Oct 25, 2007 1 Replies
Hi, I was hired for a company as a web developer and sort of IT support. I was aksed to join 2 existing networks, One network contains 25 pcs printers, a windows server that has fininacial software.
The other network contains some laptops and editors' pcs that need to have access to the internet, so it is connected straight to a linksys modem-router.
I found the existence of the server useless apart for the financial software it runs that is supposed to be accesible only from one computer.Currently this server is a dhcp server too for the first network.
I would like a solution that joins the 2 networks, (I will disable the dhcp server on the server machine). I am looking for a device, preferably linksys or maybe netgear,that will be able to handle all traffic, dhcp service, and limit access to the internet for pcs i do not want. (a complete cut off the internet). do you have any suggestions?
You need to step up in class with a FW appliance, Watchguard, Cisco, Sonicwall, Snapgear that kind of hardware solution.
You should first understand FW technology before you seek out a solution.
I am a Web and client server developer too. :)
