Print Server u/s?
Mar 08, 2005 3 Replies
T. Sean Weintz
You need to be using a crossover cable if you are directly connecting the PC to the prtint server. A regular ethernet cable won't work. Normall you don't connect the print server directly to the PC, you connect both to a hub or switch. I that case you DO use a regular ethernet…
I recently purchased a used Trendnet TEW-PS1U wireless USB print server on eBay. When I connect the server to the PC with a LAN cable, nothing happens on the PC (no network connection), and the LAN light on the server doesn't light either.
I know the cable and the PC port are functioning properly. The seller (who I believe is genuine as far as I can tell) tells me it is working as far as he knows, but he had to change the IP address. I have tried resetting the server to its factory default settings.
Should *something* happen when the PC and server are connected, or have I got a duff server please? Is there anything else I can try??
Thanks.
Regards,
Paul.
Sounds like you need a crossover cable.
Normall you don't connect the print server directly to the PC, you connect both to a hub or switch. I that case you DO use a regular ethernet cable.
Ah, thanks Sean and William. I had wondered if that was the problem. (I must first directly connect the PC and server in order to configure the wireless connection.) I would have thought the documemntation would have mentioned this small but important detail!
Regards,
Paul.
