Network Captures
Sep 13, 2005 2 Replies
If anyone out there has used SoftPerfect's Network Analyzer, I need to find a way to convert the capture files I have from their format to something more in line with a generla .CAP format used by programs such as Ethereal. I'm not a programmer, but I do have the Capture file format as follows:
CAP - is a capture file in which captured packets (sessions) are stored. Offset Size Name Description
0x0 - 0x2 3 Bytes CAPSIGN Signature line. This string value always equal to "CAP".
0x3 1 Byte CAPVER In this version of the software the value is always 1.
0x4 - 0x7 4 Bytes VTOTAL A long integer number (DWord). It is equal to the total number of data packets in a file.
VTOTAL packet records then follow the above header data. Here is the format of each variable length packet record:
- 8 Bytes TIMESTAMP A Double type number holding the date and time the packet was received.
- 2 Bytes PKTLEN A Word type number, which gives the packet's length.
- PKTLEN PKTDATA A block of PKTLEN length. This is the packet's data.
If anyone could offer a utility (Ethereal's will not work..already tried) or an easy solution, I'd be most appreciative. Thanks.
AL
In article , aerielord wrote: :If anyone out there has used SoftPerfect's Network Analyzer, I need to :find a way to convert the capture files I have from their format to :something more in line with a generla .CAP format used by programs such :as Ethereal. I'm not a programmer, but I do have the Capture file :format as follows:
It appears that there have been several different pcap file formats, some incompatible with the others.
A draft of a proposed file format is at
I have not checked how far along that got -- I do not know if it is still draft stage or is now widely implemented.
Ethereal's format must be public.
knock something together to solve this problem.
You will just have to find one?
