tNettask Suspend
Jun 09, 2006 0 Replies
HI
Our System is a SNMP Managed System.Socket listening at 161 port.
When i do a normal Get-set operation its works very fine. No problem with it. Packetyzer Trace:
But when my system receive a NBNS request packet in port 137. The Switch repond saying Destination Unreachable ( since the port is not open ). But Henceforth when i do a SNMP get on my system My system gets hanged. This happen exactly With the response to SNMP get-Reuest as soon as the system send the SNMP response message out through Socket using Sendto function my system gets hanged.
what could be the problem. We are stuck with this problem for long. Plz Help needed.
I am Attaching the NBNS packet.
Frame 1 (92 bytes on wire, 92 bytes captured) Frame is marked: False Arrival Time: Jun 9, 2006 13:59:53.-1209442328 Time delta from previous packet: 0.000000000 seconds Time since reference or first frame: 0.000000000 seconds Frame Number: 1 Packet Length: 92 bytes Capture Length: 92 bytes Data (92 bytes)
0000: 00 72 74 76 78 31 00 02 E3 15 62 EB 08 00 45 00 .rtvx1....b...E.
0010: 00 4E 02 B1 00 00 80 11 B6 41 C0 A8 00 3D C0 A8 .N.......A...=..
0020: 00 1F 04 50 00 89 00 3A 3A BA 00 01 00 00 00 01 ...P...::.......
0030: 00 00 00 00 00 00 20 43 4B 41 41 41 41 41 41 41 ...... CKAAAAAAA
0040: 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 AAAAAAAAAAAAAAAA
0050: 41 41 41 41 41 41 41 00 00 21 00 01 AAAAAAA..!..
thanx Palavesam
