data/control plane
Jan 29, 2010 2 Replies
Hello,
very often I encounter such terms as "data plane", "control plane", "management plane". Are these Ethernet specific terms or used everywhere in telecommunications domain? And the important question - what exactly do they mean, what entities they are supposed to distinguish?
Thanks.
it appears on various bits of datacomms kit - routers for example.
the idea is you have 2 types of traffic - data (lots of it, simple forwarding, so good for hardware optimisation)
- control (low volume, but there to manage the data, messy complex protocols, so often dealt with in software)
so you have 2 parts of the system, interacting but designed in different ways, and possibly implemented as partly separate sections.
separate management plane isnt something i see very much since i think of it as part of the control plane.
The concept possibly was imported for other telecomms equipment - voice switches typically have a "voice" link and separate control plumbing. And this is common in protocols - eg in ISDN where calls and signalling are in different channels.
Thanks for the explanation, Stephen.
