A GbE device not able to forward full-rate odd-byte frames
Nov 02, 2005 4 Replies
Jump to replies (4)
Hi, I have a GbE device that cannot forward the full 1Gbps rate for frames of odd-byte sizes, but can forward the full
1Gbps rate for frames of even-byte sizes. I hope to get other experts comments on this situation.
I'm using IXIA traffic generator to test the GbE device. With the even-byte-sized frames (say, 64, 512), the device can receive full-rate traffic and forward back to IXIA. However, with the odd-byte-sized frames (say, 65, 511), the device can receive full-rate traffic, but fails to forward all the traffic back to IXIA. Overflow happens inside the device.
The nominal traffic generation speed for 511-byte frames can be calculated like the following; 1Gbps / (511 + 8 + 12) * 8 = 235,404.89642
And the IXIA's input rate is 235,405 frames/sec. The forwarding rate of the device is limited to 234,932 fps due to the overflow.
The device company claims that IXIA is generating too much traffic, that is, IXIA has a faster ineternal clock than the device clock. Is this valid claim or not?
Thanks for any comments.
Regards, Jay Kim
it shouldnt matter - if the clock is wrong the the generated data would be arriving @ faster than 1 Gbps - 1/5 frame / sec or 1 part per million should be well with allowed clock tolerance
i suggest is you try this with different length tests - internal buffering probably takes up the slack up to some limit.
you have to ask whether it really matters that the device cannot handle that last 0.2% of continuous wirespeed thruput.
i suggest you run the traffic generator with 510 / 511 / 512 byte frames and see if 510 is OK as well - that should point out the anomaly on odd length frames.
FWIW odd transfers inside the device memory may have some extra overhead - but if the design is that close to the edge you should be having other issues.
Maybe they misalign internal frame transfers, so for odd length frames they do 2 DMA cycles per x bytes rather than 1? in which case this is likely a bug or hardware programming issue.
Hmm, from the numbers I would rather guess the device under test can only send even length frames and pads if asked to forward odd length ones.
Thanks for your comments. Yes, it seems that the device has some kind of internal bug when odd-sized frames are injected with the full 1Gbps rate. I tried 510, it was ok, tried
509, it failed.
The device company claimed that Ethernet standard allows 200ppm clock difference (+-100ppm) among different Ethernet devices.
I'm wondering this kind of odd-byte problem is common in Ethernet devices. I think it's not, is it?
Regards, Jay Kim
200ppm is 1 byte in 5000, you are loosing 1 in 500.
Who knows. As it makes no difference in everyday operation you will only notice by looking at the wire.
