ws-x4008
Sep 02, 2006 4 Replies
Jump to replies (4)
ws-x4008 open original image
Hi guys, the Catalyst 4000 AC Power Supply (Spare) product name is WS-X4008=, but i could not find what is the wattage for it, as far as i know they come in 400W, and 650W, so how do i specify when i order? Thanks.
WS-X4008 is a part number and specifies exactly one thing.
WS-X4008-DC-650W looks like a part number for a DC-input 650W version.
400W AC power supply for Catalyst 4000 Series chassis
Catalyst 4006 chassis supports only the 400 W AC,
400 W DC, and 650 W DC power supplies
Looks like the 650 W one is only available with DC input.
Hope that helps, is a bit confusing.
Hi Andy,
Getting "real technical" the P/N printed on the "physical label" of the WS-X4008, 400W AC Power Supply itself is actually:
34-0873-01
Furthermore, it also has the Sony Part Number APS-111
Hope this helps.
Brad Reese BradReese.Com - Cisco Power Supply Headquarters
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558 AIM: R2MGrant BradReese.Com - Cisco Repair
What would this number be used for?
To order a ws-x4008 you ask for "ws-x4008". Cisco refer to it as the "Product Number".
As I expect you all know "=" means ordered as a spare which results in everyone knowing that the ordered components are not to be assembled todether and so do not need to be 'compatible' with each other. At least that is what I have used it for.
Ordering the "replacement" of the EXACT power supply YOU currently have in your physical possession.
Sincerely,
Brad Reese Cisco Power Supply Headquarters
