WS-C3750 inter VLANing
May 06, 2009 3 Replies
Jump to replies (3)
Hi there, can I do simple inter-VLANing routing without an external router on my WS-C3750 switch? Rob
-C3750 switch?
Create multiple vlan interfaces, and enable ip routing. Don't need a protocol unless you are exchanging networks with other routers, probably just need a static default gateway (ip route 0.0.0.0 0.0.0.0 a.b.c.d) where a.b.c.d is the next-hop.
Thanks for the help Trendkill. Can I control routing, I mean I dont want routing for all VLANs just some of them. Rob
Rob only create L3 interfaces for VLANs you need routed
Albert
