Wireless Question
Jan 22, 2008 5 Replies
Jump to replies (5)
Hi, Does Cisco have any wireless switch/router or access point solution? I need to connect 5 buildings which are about 200 meters far from here. Thanks-Rob
Hi Rob,
You may wish to investigate the 5 Steps to Creating a Wireless Network:
as well as the Certified Product Listing:
"Wireless" of the Cisco Product Advisor:
and finally the "Mobility" section of Cisco's Solution Designer:
Furthermore, Cisco ConfigMaker Software may be helpful:
Sincerely,
Brad Reese BradReese.Com=AE Cisco Resource Center Toll Free: 877-549-2680 International: 828-277-7272=20 Website:
Wireless Question open original image
Guys
Does anyone know of any freeware/shareware wireless auditing tools out there for Windows. I've taken on a project of attempting to locate existing hotspots for a customer and their TS team have very knowledge of the physical locations of the equipment which is all located in ceiling voids
Steve
Not much in the way of free stuff, depends on whether or not you use Windows or Linux. The only one I know if is Netstumbler, only really good for finding Wireless AP's and a bit of information about said AP Otherwise just Google Free Wireless Tools this will give you some good results
Hope that helps
It's not free but seems like good value hardware.
Reports in alt.internet.wireless
