Newbie and stuck!
Feb 24, 2006 1 Replies
Hi I have a Cisco 877 wireless router. I have upgraded the firmware as the original version would not allow connection to a BT line, lol. I can get an ADSL connection and the connection test is successful. I have set up the router IP address to match my local network pool address with the router being the hctp host.
I can connect to the router from my network, but I can not connect to the internet from my network. Is there something I am missing? Thank you Pete
!This is the running config of the router: 192.168.0.100 !---------------------------------------------------------------------------- !version 12.4 no service pad service tcp-keepalives-in service tcp-keepalives-out service timestamps debug datetime msec localtime show-timezone service timestamps log datetime msec localtime show-timezone service password-encryption service sequence-numbers ! hostname xxxx ! boot-start-marker boot-end-marker ! logging buffered 51200 debugging logging console critical enable secret 5 xxxxxx ! no aaa new-model ! resource policy ! clock timezone London 0 clock summer-time London date Mar 30 2003 1:00 Oct 26 2003 2:00 ip subnet-zero no ip source-route ip cef no ip dhcp use vrf connected ! ip dhcp pool XXXXXXX-Pool import all network 192.168.0.0 255.255.255.0 ! ! ip inspect name DEFAULT100 cuseeme ip inspect name DEFAULT100 ftp ip inspect name DEFAULT100 h323 ip inspect name DEFAULT100 icmp ip inspect name DEFAULT100 netshow ip inspect name DEFAULT100 rcmd ip inspect name DEFAULT100 realaudio ip inspect name DEFAULT100 rtsp ip inspect name DEFAULT100 esmtp ip inspect name DEFAULT100 sqlnet ip inspect name DEFAULT100 streamworks ip inspect name DEFAULT100 tftp ip inspect name DEFAULT100 tcp ip inspect name DEFAULT100 udp ip inspect name DEFAULT100 vdolive ip tcp synwait-time 10 no ip bootp server ip domain name xxxxxxx ip name-server 192.168.0.1 ip ssh time-out 60 ip ssh authentication-retries 2 ! ! crypto pki trustpoint TP-self-signed-xxxxxxx enrollment selfsigned subject-name cn=IOS-Self-Signed-Certificate-xxxxxxx revocation-check none rsakeypair TP-self-signed-xxxxx ! ! crypto pki certificate chain TP-self-signed-xxxxxx certificate self-signed 01
quit username xxxxx ! ! ! bridge irb ! ! interface ATM0 no ip address no ip redirects no ip unreachables no ip proxy-arp ip route-cache flow no atm ilmi-keepalive dsl operating-mode auto ! interface ATM0.1 point-to-point description $ES_WAN$$FW_OUTSIDE$ pvc 0/38 encapsulation aal5mux ppp dialer dialer pool-member 1 ! ! interface FastEthernet0 ! interface FastEthernet1 ! interface FastEthernet2 ! interface FastEthernet3 ! interface Dot11Radio0 no ip address ! encryption mode wep mandatory ! ssid xxxxxx authentication open ! speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0
48.0 54.0 channel 2462 station-role root bridge-group 1 bridge-group 1 spanning-disabled ! interface Vlan1 description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$FW_INSIDE$ no ip address bridge-group 1 ! interface Dialer0 description $FW_OUTSIDE$ ip address negotiated ip access-group 101 in no ip redirects no ip unreachables no ip proxy-arp ip inspect DEFAULT100 out ip nat outside ip virtual-reassembly encapsulation ppp ip route-cache flow dialer pool 1 dialer-group 1 no cdp enable ppp authentication chap callin ppp chap hostname xxxxxx ppp chap password xxxxxxx ! interface BVI1 description $ES_LAN$$FW_INSIDE$ ip address 192.168.0.100 255.255.255.0 ip access-group 100 in ip nat inside ip virtual-reassembly ip tcp adjust-mss 1452 ! ip classless ip route 0.0.0.0 0.0.0.0 Dialer0 ! ip http server ip http authentication local ip http secure-server ip http timeout-policy idle 600 life 86400 requests 10000 ip nat inside source list 1 interface Dialer0 overload ! logging trap debugging access-list 1 remark INSIDE_IF=BVI1 access-list 1 remark SDM_ACL Category=2 access-list 1 permit 192.168.0.0 0.0.0.255 access-list 100 remark auto generated by Cisco SDM Express firewall configuration access-list 100 remark SDM_ACL Category=1 access-list 100 deny ip host 255.255.255.255 any access-list 100 deny ip 127.0.0.0 0.255.255.255 any access-list 100 permit ip any any access-list 101 remark auto generated by Cisco SDM Express firewall configuration access-list 101 remark SDM_ACL Category=1 access-list 101 permit udp host 192.168.0.1 eq domain any access-list 101 deny ip 192.168.0.0 0.0.0.255 any access-list 101 permit icmp any any echo-reply access-list 101 permit icmp any any time-exceeded access-list 101 permit icmp any any unreachable access-list 101 deny ip 10.0.0.0 0.255.255.255 any access-list 101 deny ip 172.16.0.0 0.15.255.255 any access-list 101 deny ip 192.168.0.0 0.0.255.255 any access-list 101 deny ip 127.0.0.0 0.255.255.255 any access-list 101 deny ip host 255.255.255.255 any access-list 101 deny ip host 0.0.0.0 any access-list 101 deny ip any any dialer-list 1 protocol ip permit no cdp run ! control-plane ! bridge 1 protocol ieee bridge 1 route ip banner login ^CAuthorized access only! Disconnect IMMEDIATELY if you are not an authorized user!^C ! line con 0 login local no modem enable transport output telnet line aux 0 login local transport output telnet line vty 0 4 privilege level 15 login local transport input telnet ssh ! scheduler max-task-time 5000 scheduler allocate 4000 1000 scheduler interval 500 end
Hello,
try:
dsl operating-mode ansi-dmt
and if that doesn't help, configure 'ip mtu 1452' under the dialer interface configuration.
Regards,
H
