Wavelan Bronze and AIR-AP350 and AIR-AP340
Sep 13, 2005 1 Replies
Does anybody know if the Wavelan (Lucent) Bronze pcmcia cards are compatible with AIR-AP350 and AIR-AP340 ? Also, can I use the AIR-AP350 and AIR-AP340 together to cover a wider area? I don't need encryption. I think the Wavelan Bronze should work. The bronze is a 2.4GHZ card.
Thanks, John
snipped-for-privacy@rothfield.com schrieb:
Yes and yes. If it does not work check that you have disabled first the short preamble and next the aironet extensions.
