WAAS w/ WCCP not working
Dec 23, 2008 0 Replies
Hi everyone,
We are having some problems putting WAAS (4.1.1b) with wccp to work on our network.
I am going to try to describe our network: Two client networks, A and B. Router_A (2801) is the gateway of network A. Router_B (2811 w/ NME-WAE) is the gateway of network B. WAE-612_CM is CM. WAE-612_A is connected to Router A. NME-WAE_B is installed in Router_B
Communication between network A and network B has been confirmed. Communication between WAE-612_CM and both WAE-612_A and NME-WAE_B has been confirmed.
Router_A configuration:
version 12.4
ip wccp 61 ip wccp 62
interface FastEthernet0/0.45 description Ligacao WAN encapsulation dot1Q 45 ip address 192.168.45.1 255.255.255.0 ip wccp 62 redirect in ! interface FastEthernet0/0.49 description Ligacao LAN encapsulation dot1Q 49 ip address 192.168.49.254 255.255.255.0 ip wccp 61 redirect in ! interface FastEthernet0/0.50 description WAE-612_CM encapsulation dot1Q 50 ip address 192.168.50.254 255.255.255.0
Router_B configuration:
version 12.4
interface FastEthernet0/0 description Ligacao WAN ip address 192.168.45.254 255.255.255.0 ip wccp 62 redirect in duplex auto speed auto ! interface FastEthernet0/1 description Ligacao LAN ip address 192.168.240.254 255.255.255.0 ip wccp 61 redirect in duplex auto speed auto ! interface Integrated-Service-Engine1/0 ip address 10.10.10.1 255.255.255.0 service-module ip address 10.10.10.2 255.255.255.0 service-module ip default-gateway 10.10.10.1 no keepalive
NME-WAE_B configuration:
! WAAS version 4.1.1b (build b15 Oct 10 2008) ! device mode application-accelerator ! wccp router-list 8 10.10.10.1 wccp tcp-promiscuous router-list-num 8 ! central-manager address 192.168.50.11 cms enable !
WAE-612_A configuration: ! WAAS version 4.1.1b (build b15 Oct 10 2008) ! device mode application-accelerator ! interface GigabitEthernet 1/0 ip address 192.168.50.1 255.255.255.0 exit ! wccp router-list 8 192.168.50.254 wccp tcp-promiscuous router-list-num 8 wccp version 2 ! central-manager address 192.168.50.11 cms enable !
With this configurations we see some traffic going to WAE but never being optimized. We have default optimization policies applied (TCP and application level).
Questions: =95 Have we configured wccp correctly? The objective is to optimize traffic form network A to network B. =95 Are we missing any other configuration?
Thanks in advance,
Francisco Sanches
