W2k pptp -> Cisco 7200 problem
Jan 20, 2006 0 Replies
Hello group,
Some clients in my LAN with W2k client can't connect with the server (cisco 7200 123-8.T). if I enable debug, I receive:
Jan 19 16:50:04.258: uid:260 Tnl/Sn 1143/1141 PPTP: disconnect (AAA) IETF: 2/lost-carrier Ascend: 7/Lost Carrier Jan 19 16:50:04.258: uid:260 Tnl/Sn 1143/1141 PPTP: sss-disc -> state change estabd to terminal Jan 19 16:50:04.258: uid:260 Tnl/Sn 1143/1141 PPTP: CC O CDN Jan 19 16:50:04.258: Tnl 1143 PPTP: no-sess -> state change estabd to wt-stprp Jan 19 16:50:04.258: VPDN CEF From tunnel: Received 98 byte pak Jan 19 16:50:04.258: Vi29 VPDN FS Tunnel to network: Sending 44 byte pak Jan 19 16:50:04.258: Vi29 VPDN CEF From tunnel: Pak send successful Jan 19 16:50:04.258: Tnl 1143 PPTP: O StopCCRQ Jan 19 16:50:04.258: uid:260 Tnl/Sn 1143/1141 PPTP: Destroying session, informational traceback below: Jan 19 16:50:04.258: -Traceback= 6195C6DC 6195CDDC 6195C4C4 6195C8EC
6193330C 619337B4 .....
What's the matter? some PC's can connect without problems and the connections have the same properties and configuration. parameters
Thanks. Charles
