VPN Connection Problems
May 14, 2007 2 Replies
I'm desperately looking for help. I've installed VPN Clients on two local machines and I can connect to the Main Office perfectly but I cannot see the internet from both the VPN connection and the local machine( when the VPN connection is active). Even the gateway (172.16.22.1) I'm getting from the VPN connection is not a correct one.
VPN Cleint ----->Internet-------->Router (172.16.22.51 Main Office)---------->Router (172.16.22.1)--------->Branch Office
Best Regards Ayanda Madyibi
Your IP, Mask, DNS, and Gateway should be assigned by the VPN concentrator on connect. It sounds like there is a bad configuration in there.....perhaps its own gateway is 22.1 and that is what it is providing? I'd check the concentrator..there should be no need to modify local routes on the client.
