Cisco Router problem routing for Remote Client
Nov 18, 2005 1 Replies
Hello,
My company has 2 centers main-Center and an Branch(100Km apart), they are connect by an VPN service Using Cisco 1841 and Cisco 1761(At Branch) Routers. All intenet access to the Branch is through the Vpn from the Main Center. The problem i am facing is that i am trying to establish an Vpn session through nortel VPn software to an Remote Client site from the Branch office which i am unable to connect it give an error message "Secure connection has been lost". When i try doing the same through the main center it connect without any problem.Also, at the branch office i am able to acces sites and other servers outside our network. Things to Note :
1) all traffice between the 2 centers is unrestricted.
2) On MAin router from which internet is being accessed all traffice on ports ISAKMP ESP AH is open to and from the Remote Clients VPN Router/firewall.
3) on the Branch router all traffice is open in and out to the Remote Clients Public Ip.
Now, to analyze the problem i did an ethreal packet sniffing when try to connect to remote clients VPN. the results are as follows:
1) I see traffice to the renote client site as ISAKMP( Agressive Mode), A response back from client is recieved.
2) Then there is traffice and response for ISAkMP(transaction (Config Mode).
3)Then i can see traffic from My machine to the remote site as ESP, I can see 31 packets sent but no packets recieved.
4) After about 51 seconds of the initiating the process i see ISAKMP(informational), for which i get an response back as ISAKMP(informational).
5) Immediately after that ICMP Destination unreachable, form my machine . Then i cant ping the remore Nortel fireall for 2-3 Minutes.
I have also checked the NAT translations on the Main Router . It show the ISAKMP traffice from My machine Ip to the Remote clients Firewall Ip and the ICMPerr
The problem is that i need to get this up and runningas this is Imp. Any help is welcome . Plesae let me know if u need details..
Regards, Bill
Since Cisco won't post this anywhere for us, I will. . . . .
SCeg83834 Bug Details Release Notes Symptoms: A router may stop translating packets using NAT, when a NAT entry with protocol "icmperr" is observed in the "show ip nat translation" output.
Conditions: These sysmptoms are observed in a Cisco router when the router is configured with only dynamic NAT translations with a single address in the NAT pool, or when configured using "interface overload".
Workaround: To clear all the NAT translations using "clear ip nat trans *" command.
This is a problem in recent PI6 images. It did not occur in PI6 images built prior to January 1st, 2005.
To allow additional translations to be created while the router has created one with the ICMPERR, what you would need to do is to create an IP NAT POOL containing more than 1 public IP address and perform NAT overload over it. This way, when one of the IP addresses is taken over by this erroneous translation, the other IP addresses will still be able to be used as the Inside Global address. You will also have to reduce the ICMP nat timeout so the router punts out the icmperr translation sooner making the used IP address available again.
