Upgrading Cisco 3750 switch stack with bin file
Apr 27, 2005 2 Replies
Most relevant reply
spilkinton
I haven't upgraded using just the bin file - but it should work the same... You only have to copy the software to switchA (Master). It is responsible for automatically upgrading the other switches in that stack. I think somewhere down the line when trying to manually copy the…
Upgrading Cisco 3750 switch stack with bin file open original image
does anyone has any idea to go about upgrading the ios for a 3750 switch stack using binary file? Cisco website has only instructions for using tar file to upgrade. I have tried the conventional way of copy the new bin file into both flash1 and flash2 and changing the boot config to boot with the new image. But when I rebooted the stack, only the master switch is upgraded and the 2nd was not able to join the stack as the master detected a version-mismatch. Reason for using bin file instead of tar file is because I do not need the CMS in our environment.
Any advice will be greatly appreciated.
Cheers.
I think somewhere down the line when trying to manually copy the software to both switches - something got confused...
fyi - You can use the .tar file and disable the web interface portion by using 'no ip http-server' in your configuration
----------------------------- Scott
Home of the Network Engineering Podcast
Thanks Scott!
Yes, I was expecting the Master Switch to auto upgrade the 2nd switch after the reboot but it didn't. The tar file includes the CMS which I feel it is a waste of Flash space if I not going to use it. And also if I use a tar file, I can't possibly keep both old and new versions since the flash size is only 16MB. I believe there should be a way to upgrade it using the binary file since it is available in the CCO for download.
Anyway, thanks again for your help!
