Unstable Cisco Aironet 1231
Mar 12, 2007 2 Replies
Unstable Cisco Aironet 1231 open original image
I have one Cisco Aironet 1231 access point. It does not use any kind of (server) functionality outside the Cisco device. I have one SSID and uses WPA-PSK (TKIP).
The configuration seams wary straight forward, but something is wrong. The access point seams to be unstable. The clients use long time to connect to the access point and it looses connection a lot of times a day. Can I do something to speed up the ?negotiation process? ? What could be the course of instability?
The configuration was made with the ?web configurator?, but I have a SSH/telnet dump:
Best Regards Martin
AP1#sh run Building configuration...
Current configuration : 2227 bytes ! version 12.3 no service pad service timestamps debug datetime msec service timestamps log datetime msec service password-encryption ! hostname AP1 ! enable secret 5 $1$RnrI$w5mGlfNQAFToFgZMdXySR1 ! clock timezone GMT 1 ip subnet-zero ip domain name mydom.com ! ! aaa new-model ! ! aaa group server radius rad_eap ! aaa group server radius rad_mac ! aaa group server radius rad_acct ! aaa group server radius rad_admin ! aaa group server tacacs+ tac_admin ! aaa group server radius rad_pmip ! aaa group server radius dummy ! aaa authentication login eap_methods group rad_eap aaa authentication login mac_methods local aaa authorization exec default local aaa accounting network acct_methods start-stop group rad_acct aaa session-id common ! dot11 ssid myssid authentication open authentication key-management wpa guest-mode wpa-psk ascii 7 021705415A545C365F56584B561216085D5679 ! ! ! username Cisco password 7 14341B180F0B ! bridge irb ! ! interface Dot11Radio0 no ip address no ip route-cache ! encryption mode ciphers tkip ! ssid myssid ! speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0
36.0 48.0 54.0 channel 2412 station-role root no cdp enable bridge-group 1 bridge-group 1 subscriber-loop-control bridge-group 1 block-unknown-source no bridge-group 1 source-learning no bridge-group 1 unicast-flooding bridge-group 1 spanning-disabled ! interface FastEthernet0 no ip address no ip route-cache duplex auto speed auto no cdp enable bridge-group 1 no bridge-group 1 source-learning bridge-group 1 spanning-disabled hold-queue 160 in ! interface BVI1 ip address 192.168.1.105 255.255.255.0 no ip route-cache ! ip http server no ip http secure-server ip http help-path
radius source-interface BVI1 ! access-list 111 permit tcp any any neq telnet no cdp run radius-server local no authentication leap no authentication mac ! radius-server attribute 32 include-in-access-req format %h radius-server vsa send accounting ! control-plane ! bridge 1 route ip ! ! ! line con 0 access-class 111 in line vty 0 4 access-class 111 in ! sntp server 212.242.xx.207 sntp broadcast client end
AP1#
Martin,
Your config looks fine. What could cause your clients' problems? Let's see ...
- 802.11 interference from other nearby 802.11 devices
- non-802.11 interference from other nearby 2.4GHz devices
- flaky clients
- poor RF coverage
Tools to use here:
- spectrum analysis
- site survey tool
- wireless sniffer
- client debugs (driver dependent)
Regards,
Aaron
any recomendation here? i would like to know what you are using.
M
