NAT advice for 6509
Mar 12, 2007 1 Replies
I need a little NAT advice. I am routing between 2 internal vlans,
192.168.32.0/24 and .64/24. I need to NAT these 2 vlans to the outside/public vlan 165.x.x.x. Here is the config I have come up with :
ip nat pool niscpool 165.x.x.105 165.x.x.105 prefix 24
access-list 1 permit 192.168.32.0 0.0.0.255 access-list 1 permit 192.168.64.0 0.0.0.255
ip nat inside source list 1 pool niscpool overload
interface vlan 1 ip nat outside
interface vlan 3 ip nat inside
interface vlan 4 ip nat inside
Will this work? Any suggestions?
TIA Lovejoy
well have you tried it? one question: do you need your outside interface to be a logical vlan? why not just set ip nat outside on s0/0 or eth0/0 or whatever you are using? dont forget a default route pointing out vlan 1
Flamer.
