Trasparent Bridging + bandwidth aggregation
Dec 02, 2006 2 Replies
Trasparent Bridging + bandwidth aggregation open original image
Hi all,
it is the first time i need configure a bridge with 2 routers and i wish some advice from you about that.
I need connect a new site to the old site with the same subnet
192.168.1.0 /24 (TCP/IP) and between the 2 site there are 2 serial lines both with 2Mb of bandwidth .
I need aggregate the 2 serial lines to have a channel with 4Mb (2Mb +
2Mb) of bandwidth between the 2 routers.
I have planned a configuration and before to configure them in my routers i wish know if there are mistakes or something it is better to optimize.
This is my two configurations
hostname router_1
ip no routing
interface e0 description lan old site ip address 192.168.1.1 255.255.255.0 bridge-group 1 no shut
interface s0 description serial_1 2Mb unnumbered e0 bridge-group 1 bridge-group 1 circuit-group 1 no shut
interface s1 description serial_2 2Mb unnumbered e0 bridge-group 1 bridge-group 1 circuit-group 1 no shut
bridge 1 protocol ieee
hostname router_2
ip no routing
interface e0 description lan new site ip address 192.168.1.2 255.255.255.0 bridge-group 1 no shut
many thanks
This will not aggregate the links. "protocol ieee" says to use Spanning tree to prevent bridging loops so one link will carry no traffic. If you turn off STP then of course you will get a loop which is even worse.
You need multilink ppp. I don't know a config off of the top of my head.
thanks for the answer.
Then, with that configuration will i use the serial 0 and if it is down i will use serial 1, just as back up ?
I have found out the configuration
the only difference is bridge 1 protocol ieee -> bridge 1 protocol dec
please, can you explain me the difference and how make my configuration work?
many thanks
