tftpdnld via rommon fails
Nov 09, 2005 2 Replies
I'l try to recover a Cisco 827 After entering the variables and typing tftpdnld I get the error Please reset before executing, but after a reset alle variables are lost.
What's the problem?
rommon 24 > set PS1=rommon ! >
RET_2_RUTC=0 BSI=0 RANDOM_NUM=1612852793 ROM_PERSISTENT_UTC=1014940822 RET_2_RTS= RET_2_RCALTS= IP_ADDRESS=10.11.12.1 IP_SUBNET_MASK=255.255.255.0 DEFAULT_GATEWAY=10.11.12.13 TFTP_SERVER=10.11.12.13 TFTP_FILE=c820-k9osy6-mz.123-8.T11.bin ?=43 rommon 25 > tftpdnld Please reset before executing this command rommon 26 > tftpdnld -u Please reset before executing this command rommon 27 >
The default_gateway is the same that the tftp_server?
this can`t be.....
change the ip.... and tell me.. ok ?
Regards Juan Carlos
the default gateway does not matter because the 827 and the tftp server are on the same subnet
try the following Cisco procedure:
