TCL on a cisco 3845 question from a Newbie
Sep 08, 2006 1 Replies
TCL on a cisco 3845 question from a Newbie open original image
maybe you can give me some answers to my questions:
I'm thinking of buying a cisco 3845 to test some TCL scripts - can anybody of you confirm a cisco 3845 is fine for this? Do I need a special IOS version or feature set?
The problem to solve is, to use a cisco 3845 as Gateway and execute a TCL script which overwrites the DNIS with the SIP To: number.
I hope, you understand at least a bit what I want to do.
Thanks in Advance!
Markus Ploerer
Hi Markus,
You may also wish to investigate the Cisco-centric Open Source Initiative Forum:
Sincerely,
Brad Reese Cisco IOS Software - Compatible Partner Matrix by Technology
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558 AIM: R2MGrant BradReese.Com - Global Cisco Systems Pre-Sales Support
