tab default (context sensitive help)
Apr 25, 2006 1 Replies
Hi. Is there any way to change hos the tab functions? What I mean is, is there any chance to make the router instead of making a new line with the un-abreviated sentence, just fill out the line? Understand what I mean?
Example: ALSwitch(config)#int gi (pressing tab) ALSwitch(config)#int gigabitEthernet
Want it not to make that extra line...
Terje.
I don't believe there is any way to control that behavior. There doesn't seem to be any configuration command that will suppress the printing of the newline.
Cisco da Gama
