Switching over DSL?
Jul 06, 2005 3 Replies
Ivan Ostres
How do you terminate this SHDSL? On which devices? Why would you like to extend switching over WAN?
On two locations, i have an SHDSL line. On both sites i have a switched network. Is it possible to extend the switched network over SHDSL to the other side? (MPLS maybe?)
Thanks,
R. Bressers
I'd set up a GRE tunnel over the routers, and put the tunnel interface into a bridge group along with your Ethernet networks.
Perhaps that (it was not supported a while ago on routers, although it worked), or a tag switching approach, depending on the router platforms and software, could be a solution also. You could use BVI interfaces on top of the GRE/Ethernet combinaison.
Olivier Martin
snipped-for-privacy@yahoo.com wrote:
