routing through a Site to Site VPN on PIX
Jun 02, 2005 5 Replies
Jump to replies (5)
Two 501's are connected to eachother via a site-to-site VPN:
Site 1 :
Internal IP : 10.0.0.254/24 External IP : 1.2.3.4/24
Site 2 :
Internal IP : 10.1.0.254/24 External IP : 5.6.7.8/24
Tunnelling works okay...
On Site 1 i have a router connected to some network.. The Internal IP of the router is 10.0.0.1/24. On the other side of the router i have an IP network : 192.168.0.0/24
How can i make the 192.168.0.0/24 network accessible from Site 2 ?
Thanks,
R. Bressers
normaly just set a route to the net and the network should be reachable. route inside 192.168.0.0 255.255.255.0
oli
First in both PIX you need to add a line in the no nat access-list and in the crypto access-list . And on PIX 1 , your need to add a route on your inside .
So it would give
PIX Site 1 access-list [nonat] permit ip 192.168.0.0 255.255.255.0 10.1.0.0
255.255.255.0
access-list [crypto] permit ip 192.168.0.0 255.255.255.0 10.1.0.0
255.255.255.0
route inside 192.168.0.0 255.255.255.0 10.0.0.1 1
PIX Site 2 access-list [nonat] permit ip 10.1.0.0 255.255.255.0 192.168.0.0
255.255.255.0
access-list [crypto] permit ip 10.1.0.0 255.255.255.0 192.168.0.0
255.255.255.0
Thanks.. Second question: Is there a possibility to route ALL traffic from PIX 2 to PIX 1 ? Like.. a default route to the other side?
Thanks,
R. Bressers
In article , Remco Bressers wrote: :Thanks.. Second question: Is there a possibility to route ALL traffic :from PIX 2 to PIX 1 ? Like.. a default route to the other side?
Yes.
Your crypto map ACL would have a source which matched your internal interwork, and a destination of 'any'. Don't try using a crypto map ACL that specifies permit ip any any as that will cause problems for the other side.
Your default route would be set to some device on the other side of the tunnel.
Sorry for my ignorance, but can anyone give me some live-situation configuration?
Thanks!
R. Bressers
