Strange PPPOE internet behavior
Mar 04, 2008 2 Replies
Strange PPPOE internet behavior open original image
I recently set up a 2611 router to initiate my PPPOE connection to ATT DSL. I was able to get the PPPOE to connect and everything seemed to be working how ever after a few days I started to notice that certain websites were not coming up. My setup consistes of a 2611 router that is connecting to the internet, internally this router connects to a
2621 router on a 10.1.2.X network which is also acting as a router on a stick for vlans that i have setup on a 2924 switch in a 192.168.X.X network. The problem did not seem to be VLAN specific as at least one PC on each VLAN could get to the sites that were having issues. The sites that I noticed that were having issues were Windows Update (would display a "no network connection" error after searching for updates), Craigs list ( would go to a page can not be displayed when trying to post adds) Yahoo groups ( could sign on to groups but once signed on all links would go to a page can not be displayed error) Credit card sites ( could sign in but all links once signed in would go to page can not be displayed). I tried troubleshooting this on the Windows end first by engaging Microsoft support, but we were able to determine that there was an issue with the network as once I replaced the 2611 with the linksys that I was using previously everything worked. Before taking the 2611 down I was able to do a packet sniff with Ethereal of a succesfull and failed windows update, the only glaring issue that i saw was that on the failed windows update I was getting alot of check sum errors which after researching looked like they were coming from the Gig NIC. Below is the config that I was using on the 2611, any insite or thoughts on this strange issue would be appriciated.
2611 Config ========================= Using 3078 out of 29688 bytes ! version 12.3 no service pad service tcp-keepalives-in service tcp-keepalives-out service timestamps debug datetime msec service timestamps log datetime msec service password-encryption ! hostname crossbonesEdge ! boot-start-marker boot-end-marker ! ! no aaa new-model ip subnet-zero no ip source-route ! ! no ip domain lookup ! no ip bootp server ip cef vpdn enable ! vpdn-group 1 request-dialin protocol pppoe ! ! interface Ethernet0/0 description Connection to Internet no ip address no ip redirects no ip unreachables full-duplex pppoe enable pppoe-client dial-pool-number 1 ! interface Ethernet0/1 description Connection to Crossbones ip address 10.1.2.253 255.255.255.0 no ip redirects no ip unreachables ip nat inside full-duplex ! interface Dialer1 ip address negotiated ip mtu 1492 ip nat outside encapsulation ppp dialer pool 1 dialer-group 1 no cdp enable ppp authentication chap pap callin ppp chap hostname snipped-for-privacy@sbcglobal.net ppp chap password 7 XXXXXXXXXX ppp pap sent-username snipped-for-privacy@sbcglobal.net password 7 XXXXXXXXX ! router eigrp 100 network 10.1.2.0 0.0.0.255 auto-summary ! ip nat inside source list 1 interface Dialer1 overload ip nat inside source static tcp 192.168.7.10 1495 interface Dialer1
1495 ip nat inside source static tcp 192.168.7.15 3389 interface Dialer1
3389 no ip http server ip classless ip route 0.0.0.0 0.0.0.0 Dialer1 ! ! logging 192.168.7.16 access-list 1 permit 10.1.2.0 0.0.0.255 access-list 1 permit 192.168.0.0 0.0.255.255 dialer-list 1 protocol ip permit no cdp run ! ! snmp-server community public RO ! ! ! banner motd ^CC
********************************************************************** WARNING: This system is for the use of authorized clients only. Individuals using the computer network system without authorization, or in excess of their authorization, are subject to having all their activity on this computer network system monitored and recorded by system personnel. To protect the computer network system from unauthorized use and to ensure the computer network systems is functioning properly, system administrators monitor this system. Anyone using this computer network system expressly consents to such monitoring and is advised that if such monitoring reveals possible conduct of criminal activity, system personnel may provide the evidence of such activity to law enforcement officers.
********************************************************************** Access is restricted to authorized users only. Unauthorized access is a violation of state and federal, civil and criminal laws.
********************************************************************** ^C ! line con 0 exec-timeout 15 0 password XXXXXXXXXXXX logging synchronous login length 22 history size 30 line aux 0 exec-timeout 5 0 login length 22 transport output none line vty 0 4 exec-timeout 20 30 password XXXXXXXXXXXX login length 22 history size 30 ! ! end
take a look at this Cisco doc
Troubleshooting MTU Size in PPPoE Dialin Connectivity
You know the MS tech kept looking at the MTU and as I was posting this I noticed there was an MTU setting in the code. I will check it out, thanks for your help.
