IOS 12.2 FW - Talk to cable modem
Mar 04, 2008 0 Replies
So I've seen many configs out there to get routers to talk to comcast cable, and I dont seem to be getting it to work.
This router was originally configured for DSL and PPPoE, then had VPN connection to Office. Now I want the External NIC to be DHCP and not PPPoE, Though I'd rip out the PPPoE and Add in the DHCP and I would be set, though no go.
Here is the DSL PPPoE config, what do I need to CHange to make Ethernet0 DHCP.
Thanks,
version 12.2
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname comet.olivet
no logging console
enable secret 5
enable password 7
clock timezone PST -8
clock summer-time PST recurring
ip subnet-zero
no ip source-route
ip tftp source-interface FastEthernet0
no ip domain lookup
ip name-server 10.1.0.11
ip name-server 10.1.0.8
ip dhcp excluded-address 10.11.0.0 10.11.2.255
ip dhcp pool oliver-pool
network 10.11.0.0 255.255.0.0
dns-server 10.11.0.5 10.1.0.8 10.1.0.11
default-router 10.11.0.1
domain-name olivet.haydon-mill.com
no ip bootp server
ip vrf ENM
description ENM HQ Route
ip audit notify log
ip audit po max-events 100
vpdn enable
vpdn-group office
vpdn-group pppoe
request-dialin
protocol pppoe
crypto isakmp policy 1
hash md5
authentication pre-share
crypto isakmp key keypw address xx.yy.ww.zz
crypto isakmp keepalive 300 10
crypto ipsec transform-set charlie-set esp-des esp-md5-hmac
crypto map charlie 10 ipsec-isakmp
set peer xx.yy.ww.zz
set transform-set charlie-set
match address 101
interface Ethernet0
no ip address
ip nat outside
half-duplex
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
ip address 10.11.0.1 255.255.0.0
ip nat inside
ip tcp adjust-mss 1452
speed auto
no cdp enable
hold-queue 32 in
hold-queue 100 out
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname UserName
ppp chap password 7
ppp pap sent-username User Name password 7
crypto map charlie
router eigrp 2
network 10.0.0.0
default-metric 1000 100 255 1 1500
no auto-summary
no eigrp log-neighbor-changes
ip nat inside source route-map nonat interface Dialer1 overload
ip classless
ip route profile
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
logging trap warnings
logging source-interface FastEthernet0
logging 10.1.0.17
access-list 1 permit 10.11.0.0 0.0.255.255
access-list 101 permit ip 10.11.0.0 0.0.255.255 10.1.0.0 0.0.255.255
access-list 101 permit ip 10.11.0.0 0.0.255.255 10.2.0.0 0.0.255.255
access-list 102 permit ip 10.11.0.0 0.0.255.255 any
access-list 110 deny ip 10.11.0.0 0.0.255.255 10.1.0.0 0.0.255.255
access-list 110 deny ip 10.11.0.0 0.0.255.255 10.2.0.0 0.0.255.255
access-list 110 deny ip 10.1.0.0 0.0.255.255 10.11.0.0 0.0.255.255
access-list 110 deny ip 10.2.0.0 0.0.255.255 10.11.0.0 0.0.255.255
access-list 110 permit ip 10.11.0.0 0.0.255.255 any
dialer-list 1 protocol ip permit
no cdp run
route-map nonat permit 10
match ip address 110
snmp-server community public RO
snmp-server enable traps tty
banner motd
This is a private system operated for and by Company and
Authorization from company, management is required to use this system.
Use by unauthorized persons is prohibited.
line con 0
exec-timeout 20 0
password 7
login
length 54
width 132
line aux 0
transport output none
line vty 0 4
exec-timeout 20 0
password 7
login
length 54
width 132
no scheduler allocate
ntp server x.y.z.w prefer
end
