Just learned from Cisco Document, that if I want to set up a stateful failover configuration between two PIX515E.
A normal failover architect :
- a failover cable
- check if the IOS supports the failover structure by the command "sh ver"
I would like to know when the command "sh ver" is valid :
- issue after two PIX515 are connected
- issue this command no matter they are connected together or not
I found the "failover" function is disabled when I issued the command before two PIX515 are connected....does it mean I have to purchase a license upgrade ?
Which IOS version or above will support the failover function ?
For a stateful failover, I have to purchase:
- A LAN interface for each PIX
- the Logical Update ( LU ) software module for each PIX
What else I have to purchase for the stateful failover ?
Thank you very much for your kindly help.
Cheers
